By twisterdude1009
#146266
I want to know if anyone out there has put any speaker setups that did not use a amp board like a lepai but used a 4 channel amp (2 channels for highs 1 channel bridge for low) or used an entire setup (car deck and amp)
I want to see if it is doable for battery life. I know going the car amp route will sound way better and I will be able to get a thumpin subwoofer but I dont want it to sound amazing for 30 minutes and drain the battery. Check out my project page its the one with the Fire Rescue Jeep. Im planning on having a 50AH battery at minimum for the accessories.
I was looking at this car amp Crunch PX-1000.4. My other plan was to use a 2.1 amp board hooked up to crossovers to a horn tweeter and 5-1/4 mid drive, then have an 8 inch sub and an 8 inch passive radiator on the back. (Original was just to use 2 5-1/4 full range car speakers, but I have since changed that)
