LED wiring question (with diagram / applet code)
PostPosted:Mon Sep 11, 2017 1:42 pm
by Trader5050
Hi there! So glad a forum like this exists.
I just bought my girls two 12V Jeeps from Best Choice Products. I really like them for beginner's models and want to do a little bit of modding.
Although I want to add an additional battery later (parallel for add'l run time), right now I'd like to add a few LED flashers because (1) it'll look cool, turning these into "Police Jeeps", and (2) they'll have greater visibility in the street.
My thought process was that if took a separate lead off the 12V battery, add a switch, and then split that (one for each LED unit), and return to negative, I'd be fine. According to the Amazon page they're rated for 300mA, so together I'm assuming 600mA draw total.
Cars: (Best Choice Products 12V Jeeps)
https://www.amazon.com/gp/product/B072865HYJ/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
LEDs: (12v-24v, 300mA)
https://www.amazon.com/gp/product/B071VV7Z37/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
Any issues with this? I happened across an electrical engineer (and perhaps I didn't explain it well), but they told me it would be a problem because the LEDs would be getting the full amperage pull of the "other" side of the equation, which is the original electronics (which I'm not modifying). I thought this would be considered essentially a separate circuit and would only draw what the LEDs need.
See attached.
Circuit code for http://www.falstad.com/circuit:
Code: Select all$ 13 0.000005 10.20027730826997 32 5 45
v 400 320 400 176 0 0 40 12 0 0 0.5
w 400 144 304 144 0
w 304 144 176 144 0
w 176 352 304 352 0
162 496 176 496 320 1 12 1 0 0 0.3
162 176 144 176 352 1 12 0 1 0 0.01
w 304 352 400 352 0
x 79 295 267 298 4 24 rest\sof\selectronics
162 528 176 528 320 1 12 0 0 1 0.3
w 512 352 400 352 0
w 512 144 528 176 0
w 512 144 496 176 0
w 496 320 512 352 0
w 528 320 512 352 0
s 400 144 512 144 0 0 false
v 352 320 352 176 0 0 40 12 0 0 0.5
w 400 176 400 144 0
w 400 320 400 352 0
w 352 176 352 144 0
w 352 320 352 352 0
Re: LED wiring question (with diagram / applet code)
PostPosted:Mon Sep 11, 2017 10:42 pm
by wired
I suggest adding a small fuse in there too. Other than that you are correct. Those lights are made to connect to any 12v DC power source (according to the link).
