? on brake and reverse lights
Posted: Sun May 06, 2012 6:11 pm
by pjandrade
Working on a 2010 mustang. Was able to do the lights easily. However I am looking to install backup lights and break lights (without adding break pedal). Can someone guide me on the right direction?
Thanks in advance
Re: ? on brake and reverse lights
Posted: Wed May 09, 2012 1:27 pm
by Houdeani01
You could use a relay on the gas pedal that you set to turn on the brake lights when the gas pedal is not pressed. Similarly you could put a relay on the shifter that turns on reverse lights when it is switched to reverse. This would be one of many ways to accomplish this. Let me know if you need more detail than that.
Posted: Thu May 10, 2012 10:30 am
by FASTRAKR
I am actually looking at doing the same thing right now as well as adding a gear indicator on the dash so I can tell from behind what gear she is in before she hits the pedal.
Posted: Tue May 15, 2012 7:59 am
by Houdeani01
What would you use for the gear indicator, LEDs or a gauge of some sort?
Posted: Tue May 15, 2012 9:03 am
by CJB
Houdeani01 wrote:What would you use for the gear indicator, LEDs or a gauge of some sort?
7-segment display! DO IT! DO IT! :lol:
Posted: Tue May 15, 2012 9:15 am
by Houdeani01
Posted: Wed Sep 26, 2012 5:44 pm
by jacknapier944
Good gear shift indicator Elect Diagram. :)
Posted: Thu Mar 15, 2018 1:20 pm
by D3v1L
Houdeani01 wrote:You could use a relay on the gas pedal that you set to turn on the brake lights when the gas pedal is not pressed. Similarly you could put a relay on the shifter that turns on reverse lights when it is switched to reverse. This would be one of many ways to accomplish this. Let me know if you need more detail than that.
Diagram please
Posted: Thu Mar 15, 2018 1:21 pm
by D3v1L
Diagram please
