By Kevinob
#144864
Hi all,
Recently bought a gaucho and gound there is a front end issue (where axle is bolted to tub...). A prior owner had attempted to save it with a U bolt, epoxy, and some wood.... but their solution broke again. Side in pic is the "better" side with half the notch remaining. other has both sides shaved clean... Not the end of the world and I've spotted some threads on how to try to tackle a solution for this ... but before I get started was wondering if someone near Maryland might have a spare gaucho tub? or gaucho otherwise in disrepair they are looking to dump? I could "combine" with this one with that and get my kid on the road.
Thanks in advance, Kevin
#144866
I might..... I will have to check to see the condition. The vehicle as a whole is a disaster. I'm in Nj, about 3 hours from Hagerstown, MD
#144870
By Rob222
#144872
I had a neighbor kid drive one of our Gauchos off of a two foot tall retaining wall with no front end damage. What do people do to rip the front ends off like that ? That's really cool if parts from that neglected (and saved !) Gaucho could be used to get a damaged one back out on the road.
By Kevinob
#144877
Thanks Taz! Will stay tuned to what you find. 6 hours in car might be less frustrating than X hours attempting to fix. In the meanwhile I'm starting my first tear down :)
Appreciate the help, Kevin
taz11 wrote:I might..... I will have to check to see the condition. The vehicle as a whole is a disaster. I'm in Nj, about 3 hours from Hagerstown, MD
#144923
Its not the best but the front axle mounts are good. It has some cracking near the pedal plate and the front bumper mounts. I'll try to get pics but its under 2 feet of snow at the moment. Might take a bit.
#144998
Sorry for the delay...Mother nature had other plans....
These are the damaged areas. The front bumper area is common and can be repaired with a section of angle inside the tub. The crack by the pedal is under the pedal plate and probably due to the heavy equipment that drove over it. It is faded and chalky around the edges. All the mounts are solid and its free if you want to come and get it.
ok now i show to make a new wire setup.... i show […]
I went through this exercise about a year ago and […]
Ford F-150 gear box
Here you go: http://www.mltoys.com/Power-Wheels-Hu[…]
source for 6V 18AH battery?
Ugh. :) Question as I consider battery stuff::: W[…]
