By Tythejeepman
#145348
Thinking of selling these, you would have to trim the excess plastic of your pedal to make it look clean, attachment would be by medium length rivets I will make sure the holes where the rivets go are drilled down so the rivet heads don't snag a foot well pressing the the throttle I will file the edges as smooth as possible with a metal file for safety I am thinking around ten dollars plus shipping per pedal or if you want to meet I can do that in central michigan! Here's the one I did for my Bigfoot let me know if you would like one! These are made out of the nice thick polished aluminum diamond plate so flimsyness wont be an issue its a little under a 1/4"'thick!
By Tythejeepman
#145353
Should be fine I'm filing all the edges with a metal file smooth plus I'm going to use a larger drillbill to let the head of the rivet set down in the hole deeper so that it don't chew up tenishoes or the little ones feet :)
Gaucho Grande gearboxes
