#148590
Cool video. I'm trying to do something similar with the same model corvette, except I'm going to keep it at 12V and try adding soft start, and maybe proportional throttle.
It's a shame what happened with that motor. I wonder if there's a way to fix the terminals or something.
How does that car run on grass? Ours is still sitting in the box until I get all the pieces together.
#148599
First and very important you are not removing the window all the way because the steering wheel is attached to it. You are just loosening it and moving it aside so you can run the new harness and have access to remove the screw holding the harness in place by the peddle.
There are 6 screws total on the window. Two in the back and 4 up front by the battery. After you get all the screws out pull the front window up and then loosen the tabs in the back of the car where the window flows to the back. Finally pull toward the front of the car. The front 4 screws are like pegs so you have to pull up.
Its going to be tight because the steering wheel is still attached but you should have plenty of room after you get it loose to run the new harness.
I hope this helps.
Lightning McQueen lowered
Unibody Jeep Stock Lift
Looking for front and rear modules
Stock lift for unibody jeeps
Are the front and rear modules used for “sto[…]
The Barbie Jeep make over
Here are a couple pics of the upgraded all metal[…]
