#146407
New to this, I tossed in a 12v battery and my son loves the boost, it only has one gear box a 6v one as it originally had a 6v battery maybe 7..
It's a simple forward reverse setup no high low.
My question is should I series the batteries or parallel them? Any tips on installing the second gearbox as far as wiring goes? Should I just piggy back the new gear box in opposite polarity to the other side?
I agree on using an ESC instead of the drill trigg[…]
i am curious, can’t seem to find this anywhere. bu[…]
"Best" Choice JEEP
Chances of both motors failing are slim. Can you r[…]
Sounds like the relay coil may have failed. Make s[…]
