#146677
Hi guys!
Amazing community you have here, I spent way too many hours reading over other peoples mods before I decided to finally get mine done.
I have a the Wrangler model, Ive already got 2x12v all wired in with 30A fuse, everything is good to go, I just need the upgrade motors.
This is the stock motor :
16T
From the stickied thread here: viewtopic.php?f=41&t=19903 I found a source for the engine and what I must assume is the right pinion to go with it.
I want to drop in 775, can I just get confirmation before I order that this is what i need?
Motor: http://eastcoastpowerup.com/Motors/775_Motor
Pinion: http://eastcoastpowerup.com/775_Motor_Pinion
Question: Can I drop in this 775 motor with a 22T pinion? Will it fit the current gearbox without changing anything else?
#146680
Looks like you have a stock 16t pinion. You will have to stay with the 16t 32pitch pinion to keep from binding the motor pinion with the 1st gear in the gearbox unless you are moving the motor mount point further away from the 1st gear.
#146681
Before changing motors, your first step really should be the ESC kit he offers. Any other mods just lead to carnage if you don't have the ESC Z in place
AH HA!!!! forgot to tighten #12 on the B side...
Just did this upgrade https://www.impactbattery.co[…]
Connector identification
Curious if anyone could tell me what exactly this […]
Remote Kill
Hey all, New here and just got my son a razor forc[…]
