By Sebgaut01
#146901
Hello, I have a Peg Perego RZR 24v, I had a problem, it did not work, so I ordered a new pedal, a new board and the reverse switch. I changed everything, now it works, contrary when I push the pedal the truck goes in reverse. I try to connect the old board, same result. Then I reconnected the old reverse switch, same result. I was wondering if the polarity of the motor could be the problem, I have two new 350w engine that I had to install but it currently has both original engines.
I do not understand my problem, the wires on my pedal are well connected, red top, middle white and blue below, the contact switches are clean.
So I still have the engines to know if I can reverse polarity. I also replace my batteries with Enerwatt 12v14mah ..
So I need help !! thanks
By Bigmac41288b
#146902
When you replaced the batteries did you get the polarity correct? If those are installed backwards it would switch everything in the system to work backwards.
Luckily these things all break down pretty easily,[…]
Cool thanks for the info. Am I still ok to run the[…]
Hello all from the UK
Hi everyone New to the scene, have a 4yo boy and […]
