#147106
I have a stock 24v rzr with no upgrades except rubber tires. It was cutting out under load before so I swapped the thermal switch for a 40 amp fuse. Well now it is still cutting out under load but it is not blowing the fuse. It will cut out middle of a hill or something and start rolling backwards... then if it sits for 20-30 seconds it will start back. No noises or anything. It has the newer board and shifter with the pedal with the yellow slider for high and low. I recently put a complete overhaul kit on it, so every component is new. Does the board have some sort of heat protection built in or a current cut out or something?
Help please!
#147144
Does the new board still have those yellow things that I can't remember the name of? Lol, some help I am!
#147259
Sorry, haven't been on here much. I believe you have a pair of thermo-switches in a little black box, unplug them and install fuses in their place. Might help
Fall Fun..
The boys have cooled a bit on the power wheels, bu[…]
Very cool! How far do the side rails (mounted to[…]
Peg Perego Gator
Help. 6 volt not enough.
