By Ron_J
#147311
So my grandson decided it's cool to start up our hill, only to let it coast backwards to the bottom. Pretty harmless...but it kills the buggy. If I turn it on it's side and beat the bottom a couple times it comes back on.
I seem to remember reading about a tilt shut off??? or something of the sort...but I can't seem to find it again. I haven't had a chance to pull it apart to check for a loose connection, but I kind of doubt that's the issue.
Anyone have any suggestions? (besides, don't do that. :D )
#147312
Powewheel stock batteries have a built-in self-resetting breaker. Any chance it's just tripping the breaker from riding up the hill? They reset after a short period of time but will start tripping earlier and more often with use.
By lexx0116
#147318
Yea if you use stock battery, that will happen. I have dune racer for my kids and going up hill is a pain. Once in a while like that and I have to wait a little bit before start riding again. Might want to upgrade the battery with fuse for longer run time if you still use stock battery. It could be the wire too who knows though until you open it up just to be sure.
Higher Amp Hour
Nope, as long as you can physically fit the new ba[…]
How did this work out? Im in the proccess of doing[…]
