By Shambosley
#147342
I need help troubleshooting my sons 24v 1000 w full esc dune racer. Today he drove it around for about 45 minutes and the resetable fuse breaker flipped. Upon ressetting it, it now goes full speed by its self, without the pedal being depressed as soon as I reset it. I'm sure someone has had this problem, any ideas where the cuplrit is? Thanks in advance
By Shambosley
#147348
Okay, so I found that the motor connectors(yellow and blue) coming from the ESC were melted. I replaced the connector and the motors still spin wide open as soon as I connect the batteries. Fried ESC?
#147350
Bummer -- 99% probability that the ESC is fried. The FET drivers usually fail "shorted", which will run the motor at full speed.
Higher Amp Hour
Nope, as long as you can physically fit the new ba[…]
How did this work out? Im in the proccess of doing[…]
