By Tythejeepman
#147373
This what I started out with on the left, what's been done so far? The jeep had no motors, gas pedal, and two baby front tires so far I've trimmed the fenders up front to clear the massive Silverado tires, used extended Silverado steering components, and threw a set of Barbie cruisin tune jeep motors in it and a Barbie gas pedal in it, put in the extended silverado drive shaft for the wider wheel set up in the back, then added diamond plate accent wrap on the door handles and made side plates out of the wrap, got the stock am fm radio working in it and painted the jeep and wetsanded it! Things to be done will be a light kit, a chrome wrapped grill, and an 18vlt power system with a plug a quick plug in charger, the max speed will be 7.5-8mph in high gear!
Fall Fun..
The boys have cooled a bit on the power wheels, bu[…]
Very cool! How far do the side rails (mounted to[…]
Peg Perego Gator
Help. 6 volt not enough.
