By Kyle
#147552
Is there some glitch in the forum search engine? I am looking for info on wiring working brake lights to a Hurricane, and when I went to search, I typed in Hurricane Brake Light
I get a message that all 3 words are too common... is there some secret to searching here?
Please don't tell me that I need to search for answers to using the search feature lol
#147554
Sometimes if you search from within the subject tab instead of the home page it helps but it (search funtion) has never worked very well. I sometimes google the question and it leads you back to this site. Check these two links and see if it helps:
http://www.modifiedpowerwheels.com/foru ... IC_ID=2474
By Kyle
#147559
Thanks!!
I’m not looking for a functioning brake pedal, more wanting brake lights to be activated when the gas pedal is released
Need wiring help
Any success?
John Deere Toy Gator HPX Help
I am new to this forum and unsure if this post is […]
Volts but no movement
Check battery voltages with pedal depressed. If vo[…]
Battery questions
1-Batteries are gone. Good rule for charging batte[…]
