By michealmyers
#147629
Question about a razor quad I'm sure someone has some knowledge about these. New batteries, new controller but still nothing happens. The green indicator is on the throttle but no power. Could it possibly be the motor?
By Rob222
#148305
My guess would be the hall-effect twist throttle is bad. The motor and controller on those are pretty tough.
Just temporarily run 12 or 24v directly to the motor connector to test the motor.
We have 3 of the Razor quads and I have found (on the newer ones) that after turning on the power switch you need to hit the brake once (a built in safety mechanism ?) and then the motor will run.
Battery for stereo system
You're not the average blog author, man. You surel[…]
"found that drivers side goes forward in both[…]
Krylon Confusion
I’ve painted most of my stuff with krylon fu[…]
Kid Trax Dodge Ram bucking
Either the foot pedal switch is not making a good […]
