#148282
Hi all, got the overhaul kit as a gift for the kids for Christmas and just finished installing it...there was no wiring diagram for the new circuit board, but it was all pretty straightforward. However, I plugged in the battery to test and to push the gas will send the vehicle into reverse at regular and high speeds. The reverse lever will make it go forward except in low gear only. Is this a reverse switch problem, a pedal problem, or a circuit board problem? Any help would be appreciated.
Have you done any testing of voltages at various p[…]
Higher Amp Hour
Nope, as long as you can physically fit the new ba[…]
How did this work out? Im in the proccess of doing[…]
Hi all I’m new here this might of been cover[…]
