By BobbyP
#148639
Have a jeep huricane, worked fine last summer now only works in high gear. Just installed a new shifter with switches, same issue. Any suggestions?
#148640
With the vehicle lifted, does only one wheel spin in high gear? No reverse and no low speed fwd?
i am curious, can’t seem to find this anywhere. bu[…]
I haven't tried any of the drill switches, but mos[…]
"Best" Choice JEEP
Chances of both motors failing are slim. Can you r[…]
Sounds like the relay coil may have failed. Make s[…]
