By DougNC
#149385
Hi, guys. I hope you can help me with my son's truck. It is a Rollplay Chevrolet Silverado, model W461. I bought it in 2015.
For about the past year, it has not worked right. The OEM battery would charge to only about 4 volts, so I replaced that with a generic brand. It charges fine. Now the truck works for a split-second then quits, then work intermittently for a second. The foot pedal switch tested OK with an ohm meter, but I replaced it anyway. Still it works for only a split-second about every 10th or 15th time you press the pedal.
It quit about 18 months ago, and I turned it upside down and jiggled some wires, put it back on its wheels and it worked fine for a while. That hasn't helped this time.
Suggestions are welcome. It'd be nice if he could play with it again before he gets too big. It is kept in the garage.
Battery questions
