By Ron_J
#149398
Can anyone give me tips on removing the wheels from a dune racer? Mainly the center cap...I thought it just popped off, but I pried pretty hard on it, but nothing.
I think we have a stripped wheel gear? The one wheel is slipping, and it doesn't seem to be coming from the motor gears.
#149399
The center caps usually have three finger type clips that just press into place. Find one of the fingers and lightly pry it towards the center while slightly pulling away from the wheel. Once one of them pops out then the other two will follow with the same technique. If you pull the center cap away while looking at the base you should see what I'm trying to describe.
Hi, i have a problem with grande gaucho. The probl[…]
3B Gearbox on 12v?
