#149409
Hi, I bought a white land rover ride on with remote off of Craiglslist. The previous owner paid $400 for it but sold it for $25 because it did not work. I figured it probably was the accelerator but turned out to be simply a new battery was needed. I don't know the brand or have a manual. I could t figure out how to get the remote working.
It ran fine even after I replaced it with a 12V sealed battery. It originally had a small brick charger with a pin connector you insert into a charge port below the seat. I got tired of having to remove the seat every time I want to charge it so I tried to get cute and replace the port with the standard power wheels harness since I have that charger. Now it will not move when I press the pedal. I tried bypassing the pedal but still nothing. I am pretty sure I did it right. Sound, LED lights, and power switch works. I sent see a fuse. Any suggestions on where I should look? Thanks.
Peg Perego Magica parts
You can send me an email with what you have. My em[…]
Software Testing
New Here!
