By suokia
#150726
After 3 years a problem occured. I guess because one kid pulled the quad back with his hands while another one was accelerating.
THe problem is quite strange however.
It works only with gear 2 now, no 1 and no reverse but:
1) with gear 2 often only the left rear wheel does work
2) if i gently push (or pull) the quad, both gear 1 speed and reverse work
3) i tried unplugging the cables of the right wheel (the one working intermittently) and the problem with 1 and reverse still occur
4) the pedal looks ok cause it's not working intermittently: the 1 and reverse only works if i push gently the quad, and in gear 2 it always works
What's broken? The right motor? The shift?
CJB Performance HELP/SUPPORT
emailed you.
Perego power connector
