By K0demonkey
#42643
Is there a tool you can buy to put threads on the end of the power wheels axles to do away with the push caps?
I'd like to get away from the push caps so that I can easily swap/modify the wheels on my power wheels.
Shan
By wkearney99
#42665
There's likely NOT enough length to get nylon insert nuts in there. I know, I tried on one of my Jeeps. The good news is you can spend $6 to buy a 7/16 metal rod, cut it to the needed longer length and then put your own threads on it. Putting in a whole new axle is trivially simple. Just remove the old one by popping off the pushnuts and sliding it out. It's that simple.
Another alternative is a threaded collar. I picked up some from McMaster-Carr to see how they'd work out, but haven't installed them yet. They're damned pricey though, a lot more than a fresh axle and your time with a thread cutting die.
Yet another alternative is to drill a hole through the existing shaft and put a cotter pin or other retaining clip through the hole. HF sells a V-shaped drill press guide that makes it very easy to get the hole perfectly centered. Or if you like, thread the end and then drill a hole through BOTH the nut and the shaft. This would guarantee the hole would align with the nut, as it's nigh on impossible to do it otherwise. Or use a slotted (aka castellated) nut as they're designed for use with a cotter pin.
By wkearney99
#42703
^ plenty indeed, in some cases way too much. I've got a lifted Fire & Rescue with the 14" tires and the was at least 2" too much axle. For the stock plastic wheels there's barely a 3/8" (if that). So for rubber ones I'd still recommend cutting a shorter axle from a fresh rod.
I have gotten rid of the chassis now and only have[…]
I'm looking for some help on my mini moto go kart[…]
Did you figure out why you where blowing motors? […]
Solstice no power th wheels
The radio comes on but that’s it.. can anyone help[…]
