Have a good/bad experience with a seller or buyer? Post it here. Not a bash session, see inside for guidelines.
By lutdaddy
#138635
I have some wiring questions about the kid trax fire truck - I see how the drawing works just basically confirming a few things about the best way to go. I got her breathing again - lights, siren, etc. and it would run for a short time but likes to reset often. After trying to rewire it outside that area under the seat, she's not breathing anymore. I must have done something different when redoing it all. Basic question is - does the wiring across relays need to be in series or can I connect all the 85s with a wire nut and then female connector to each relay. Does it matter either way? Also I lumped all black power wires with small black cut from original plug, and all red with small red cut from original plug. This creates some larger wires connected in with smaller - is that ok?
Date code decoder?
