- Thu Jul 07, 2011 9:27 am
#28624
posted by: chopper
Posted - 10/28/2006 : 12:34:13
This question is a little hard to answer. It all depends on the different factors involed, so there really is no hard answer.
The average you could expect to recieve from a brand new 12 volt sealed lead acid battery, with a 50 pound kid on pavement, should be a little over an hour. Here comes the it depends part. If the battery is older, then not as long. If the kid is lighter/heaver, then longer/shorter respectively. If it's ridden in grass/uphill/rough surface then shorter run times could be expected.
FREE is always better.
