FAQ- Simple 18volt conversion for dual 6volt systems
Posted: Wed Jan 12, 2011 8:29 pm
by taz11
This conversion is specificly for dual 6volt (12volt) systems that utilize a single wire plug for the high speed lockout. The plug lockout system was used on most dual 6volt Power Wheels with push button shifting.
By simply unplugging the lockout plug, you now have a perfect location to connect another 6 volt battery. This will provide 18 volts in high and 6 volts in low.
Here is a diagram that should help explain it. (wire colors may vary)
dual 6 to 18volt mod.jpg (40.75 KiB) Viewed 8731 times
It is very important that you follow the diagram exactly since the connections are polarity sensitive.
Here is the finished product.
_18v bigfoot hookup.jpg (45.83 KiB) Viewed 8731 times
Check out the original thread here:
http://www.modifiedpowerwheels.com/foru ... C_ID=18865
Another note: Some older models with #3 gearboxes had plastic pinions. Plastic pinions will not hold up at 18volts. They should be switched to metal ones -OR- refer to "#3 plastic pinion fix" here: viewtopic.php?f=41&t=607
Re: FAQ- Simple 18volt conversion for dual 6volt systems
Posted: Tue Jul 26, 2011 6:11 am
by cadis12
Can I still do this trick with the dual 6volt to 12volt wire harness mod?
Posted: Tue Jul 26, 2011 6:49 am
by taz11
cadis12 wrote:Can I still do this trick with the dual 6volt to 12volt wire harness mod?
No.....once the harness is "flipped" to use a single 12 volt, you can add the extra six volt inline at the main battery connector.
