By jawarren77
#129219
Picked up a fairly new Dune Racer off of CL yesterday for $20. Only problem is that I think the gears for reverse are stripped. When in reverse it doesn't spin with any weight on the wheels, but when you lift the wheels up they spin.
By hkayssi
#129224
jawarren77 wrote:Picked up a fairly new Dune Racer off of CL yesterday for $20. Only problem is that I think the gears for reverse are stripped. When in reverse it doesn't spin with any weight on the wheels, but when you lift the wheels up they spin.
If it works properly in the Forward position without grinding and clicking, and if you don't hear the motors spinning and grinding in reverse, the problem would be a bad contact inside the Forward / Reverse switch and all you have to do is open it up and clean the contact then reassemble or just replace if you don't feel comfortable doing that.
By jawarren77
#129254
motors do spin, thats why I think they are stripped.
By jawarren77
#129556
took the shifter off, unplugged harness from switches and put it back together and all is working as it should. Best $20 I have spent! Now I just need to figure out how to tighten the turning radius.
By jawarren77
#130017
Found out why the gears were slipping. It was the wheel/gearbox wasn't tight and the wheel was pulling away from the gearbox/hub. Drilled a hole in the alxle and put in a cotter pin, problem solved. Best $20 I have spent.
sorry I forgot about the loc.....I am in the Pitts[…]
jeep hurricane on pneumatic tires
There may be enough plastic to reassemble with the[…]
Hi everyone
Hi guys here Federico and my son Edoardo from ital[…]
I am afraid the gaps you have around your speakers[…]
