By hyoan
#141688
I'm new to the forum and have been looking into an ESC. Sorry if this is a stupid question in advance.
Can I just use an ESC from an R/C car, connected to the battery, and gas pedal to control the throttle in my son's jeep? Or are there more steps involved? I don't want full RC, just throttle control.
Can I wire it up like this and attach the red, black and yellow wires to the gas pedal?
http://www.uselesspickles.com/files/pic ... iring6.jpg
By hyoan
#143693
I never received an answer but I don't think my suggestion is possible. Probably has to do with voltage and the pedal. I ended up buying the plug and play kit from East Coast Power up.
By Sedzy
#143799
It can be done, but not a simple swap.
A few things need to be considered.
1. Voltage. Your RC gear probably runs at 7.2V not 12V.
2. The ESC will probably be for a BRUSHLESS motor. Your Jeep will have a BRUSHED motor.
3. The ESC uses what is called RC PPM for throttle input. Foot throttles supply a linear voltage.
You'd be better off buying a PWM driver, a foot throttle and using that instead.
By A_J_K77
#147504
Is Possible up to 18V for a resemble price,
I did it whit the car for my kids.
I used a cheap Chinese ESC (320A up to 16 V but it can handle a full charged 18 V battery!!!)
A cheap Chinese Hal sensor foot throttle connected to a cheap Chinese Arduino clone
whit a switch for forward and backward.
the Arduino make from a analog signal a RC signal.
I use also a transmitter / receiver for Remote control, on the 3rd Ch.
I connected a reed relay to switch from local to remote.
It cost abound $ 30 or so
for more info and the arduino code just contact me
Adjustable Brake Reduction Mod
Thank you so much for this idea! I was just going […]
Yes, You can run them in series but it's not[…]
I read the FAQ - The Definitive "Gearbox"[…]
http://kellycontroller.com/kds24050e50a12v-24v-min[…]
