#129588
Need more advice. I'm converting an 850 quad to 36v esc and a twist throttle. How do I activate my brake? What will work best in a panic situation? Do I make the original gas pedal the brake? Do I reverse it so it has to be pressed to release the brake? A button on the handlebar? Help! :?
#137160
I used the original pedal as release-to-brake though I can't say it's super intuitive since you get accustomed to the twist throttle and forget your foot is pushing anything
#137244
wesleyb82 wrote:Brake lever with integrated microswitch to use as the brake?
http://www.monsterscooterparts.com/brakelevers.html
In hindsight, that would have been much better. It's not like they will break the bank even purchasing new anyways...
#137267
since its just going to be used as the brake do you think you need a relay or can I just hook it up straight the the orange wire on the throttle switch? I wouldn't think it would carry much amps while braking.
You will definitely want a relay. The microswitch can't handle much amperage and those motors can generate a ton of power under heavy braking!
#137275
sounds good thanks
#137284
toycrusher wrote:You will definitely want a relay. The microswitch can't handle much amperage and those motors can generate a ton of power under heavy braking!
++1 !
Anyway in my custom building experience a lot of times there is no need to re-invent the wheel- look at what is already in use and working. In this case scooters have controls that include a brake on the steering bar. Big Co's spend big bucks to find out what works. Anytime I see a scooter, power wheels, etc I take a close look and check out what millions in R&D results in.
It's only the housings that are different: small a[…]
Need wiring help
A potentiometer is a three-terminal resistor with […]
Motion Trendz Buzz Lightyear Car
So has anyone found a good place to find these gea[…]
Exploding Controllers
I would double-check the battery/wiring polarity -[…]
