By Daniel
#136114
Hello,
can you explain me the difference beetwen a stock on/off throttle, that brakes when you remove the foot from throttle, and an ESC brake function ? What happens when you remove the foot of an ESC powered PW ?
Thank you !
By sall
#136127
The brakes on the common ESC setup short the motors out to brake. Braking can be softened with resistors. The brake must manually be pressed. If you let off the accelerator all that happens is the vehicle rolls to stop.
One could set the brake relay up so it's always active when the throttle is not being pressed though to emulate the factory setup.
By wesleyb82
#136244
sall wrote:One could set the brake relay up so it's always active when the throttle is not being pressed though to emulate the factory setup.
Check out this thread for automatic braking with ESC but in my opinion the friction of the gearboxes does a pretty good job slowing down the car and adding the additional level of control (coasting/ hard stopping) really allows the young drivers to explore the new control and learn new techniques which is more fun for them and frankly very fun to watch as well (young kids pick up things super fast as we all know). Unless there are special circumstances, if I were you maybe try to run the regular ESC setup first then explore the automatic braking later if you think it would be beneficial for your circumstances.
viewtopic.php?f=46&t=15661
Hello new to modding PW :)
Hey Guys i'm new here to modding PW's just started[…]
It's only the housings that are different: small a[…]
Need wiring help
A potentiometer is a three-terminal resistor with […]
Motion Trendz Buzz Lightyear Car
So has anyone found a good place to find these gea[…]
