#136361
Found this by accident on craigslist got it home Friday night and by Sunday night we where riding it and drifting it on the wet street.
Specs:
Original: 500watt 2500rpm @ 36 volts top speed 15-18mph with 120lb rider
Currently: Industrial .75hp 3600rpm @ 48volts top speed 22mph with 200lb rider and arm yanking torque. :) 29mph @ 60v
Now I am looking for a cheap-ish plastic or fiberglass gokart seat. The original one is tiny for my 220lb frame, and would also like to find a front wing for it. Even a broken wing that I can repair or make a mold of would be perfect if anyone happens to have one taking up space. :)
Now for pics! and once I repair the flat tire I will post video!
Originally looked like:
Little rough around the edges:
Here she is naked:
New motor compared to old motor:
Put together and ready for test ride:
#136662
Wow the cart on the bottom is awesome with suspension front and rear but what's up with the apparent emergency disconnect behind the seat?
#142476
Looks great.
I just picked up a minimoto. What is the model number of the Nilfisk motor you are using? I'll see if I can find one. I want to make this one to ride myself so my boy and I can have fun together. What controller are you using?
#146341
Gwagon wrote:Looks great.
Any industrial motor will work. Find one that is .75-1hp and 24-48v. Nothing special about the Nilfisk other then it was the cheapest I could find at the time.
#148703
[need help on wiring, picked up a Minimoto go kart a few years ago, am finally trying to get it running. Problem I have is that the wiring connections aren’t complete, can you post pictures of where the cable that comes out of the steering wheel the one that is zip tied to the buzzer, where do I connect those?
Trouble installing alternate switch
Hi all, I am a pediatric physical therapist and mo[…]
"Best" Choice JEEP
Where would I start to look into that? I was wonde[…]
Roadside Jeep Limited rebuild
Well, a major finger injury took me out for a few […]
This drill: http://www.hitachipowertools.ca/en/Pro[…]
