By Siegelracing
#138898
So, I really like the "idea" of using a potentiometer based ESC; they're cheap (under $22 shipped), robust (10v-50v and tested with 180lb drivers), but...
I'm totally failing at finding a decent pedal solution. I've seen this one:
viewtopic.php?f=26&t=1724
but I really feel like there's got to be a cheap, easy, available solution with a 100k potentiometer pedal... xbox / pc / gaming pedals?
I use the metal scooter pedals usually.
Date code decoder?
