By Siegelracing
#140044
12vwiz, Toycrusher, 66Duece, Taz, help!!! :)
It's killing me... I'm an engineer (but mechanical, not electrical) and I thought doing 12Vwiz's relay board bypass but with Toycrusher's ESC wiring diagrams and 66Duece's potentiometer based would be awesome and "straightforward" or at least that I could figure it out... And maybe if I had started earlier in the evening I would have...
So, I used 12VWiz's fire truck relay with NOS setup, and I think I can use the separate brake pedal (being open) to "trigger" the throttle, and use the ESC to power Relay 6 with 12v whith the NOS/Turbo switch off and 24 with it on.
It got late and I got frustrated, hooked the battery up backwards and and I let more magic smoke out of the circuit board, which I'm only using to power the lights and sounds... The board still does that but a relay clicks when I hook up the battery, regardless of key position. I don't want it to kill the battery and I was planning a remote kill anyway, so I might have to use that to turn it off...
My daughter's birthday is next Friday... :/
All help (wiring diagrams would be awesome) is MUCH appreciated :)
Cordless Tools
