#141958
I have two 24V Gaucho's with ESC for about two years now.. I get batteries every year for them..
My one is running very slow.. I have a voltmeter connected to it and it definitely was on a low charge (24V) and it goes down to 20V when the pedal is pressed but it literally crawls like this.. With a full charge it runs fine just wondering if this is normal or if I may have a bad battery?
Thanks
#141969
How long does it run before slowing down?
#141971
To test the batteries, swap the batteries between the two. Fully charged the batteries should read close to 26v. I just checked and mine are at 25.9v.
Are they stock Gaucho SuperPowers or 12v Gauchos modified with a 24v ESC upgrade ? If they are SuperPowers the throttle cable may have stretched or slipped out of it's pocket. SuperPowers use a remote hall-effect sensor in the rear of the jeep connected to the pedal by a cable. Lay a towel down to protect the tail lamps (or remove the rear bumper) and flip the jeep on its rear. Check the cable. Use a plastic zip-tie to shorten it if needed.
Cordless Tools
