#146285
I have installed an ESC DYI from EastCoast and am having issues getting it to have power to run. I have tested as indicated on site and am still having issues. Is there anyone on the Northern California area?? And has this been an issue for anyone else? I have wired and then rewired system and it still won't work, yet appears to be wired as is shown on the instructions.
#146376
Honestly Wesley offers amazing customer assistance and tech support. I'd recommend reaching back out to him first as he knows exactly what components you have
#146427
Hello. I purchased the 500w DIY ESC kit from EastCoast and had some issues with installation which I have now resolved. My issue was with the Controller itself. The one that shipped with the kit didn't work (which I was informed might happen from the get go). I purchased an extra Controller from ebay which also had issues. Controller 1 seemed completely dead. Controller 2 would run the motors full throttle as soon as I connected the battery even without the key ignition engaged. I purchased an additional 2 controllers from Amazon and one of those finally worked.
I had found one of the YouTube videos from EastCoast that described troubleshooting. I basically tried to compartmentalize each section of the wiring and tested that section only. For example, I connected the battery directly after the 24v step-down to confirm that my wiring for lights and switches all worked. Next, I tested the on/off switch. Lastly, I redid the wiring for the relays multiple times and double checked that I hadn't broken anything during install.
It definitely was a frustrating experience for me but I'm glad I was able to resolve things in the end plus I learned a lot at the same time. EastCoast provided helpful feedback along the way as well.
Cordless Tools
