#146457
1st post.
I just want a robust variable speed twist throttle...here is my currebt situation.
I had a bad yk31c unit that smoked at the first twist of the hall throttle. Very frusterating. I believe I'm understanding that the potentiometer-based units are much more reliable. I want reliable. I also want a smooth twist throttle.
If I get a new pot-regulated ESC, how can I use my existing hall throttle? I'm assuming wiring it directly in place of the pot is not an option.
Thanks in advance.
2 things.. where do I find a 19t pinion and how do[…]
Hi just introducing myself
