By dka56
#150736
I picked this up awhile ago, just getting around to installing it. This will be going in a Polaris Sportsman 850. I currently have a pair of 50A relays it want to switch to the KDZ.
I have a hall effect throttle, push button brake, and reverse selector. I'm curious if I need the diodes and resistor or just wire in the throttle, brake, and reverse switch then set up via pc.
Thanks....all input appreciated.
I am just confused about that resistor. Actually I[…]
Foward reverse gear help
The ram dually toy foward reverse lever handle sw[…]
Some questions and advice
It's hard to say. You can get a nice price if your[…]
