By Beverage55
#133544
I am new to this site but I was wondering if anyone could help me I bought my daughter an fj cruiser last year it was left outside over the winter I replaced the battery but im not getting power out ive had the shop I got the battery from test it in front of me and it is charged could the motors be bad and if they are where can I get new ones?
#133615
Use a DVOM reading voltage, hold the gas pedal down, put your ground lead on the battery and then the power lead, start tracing from the battery, to the pedal, to the shift switches, to the motors, and so forth until you find the place where you are losing your power. It's unlikely for both motors to go bad when you are testing in "high". If you are testing in "low" or "reverse" then one bad motor (or connection) would keep both sides from working.
Cruisin McQueen (nz)
NICE ... that is sweet.
