By xtreme6669
#137824
I was given a 6v motorcycle that had a bad battery. I removed the stock faulty battery and installed a 12V 12ah sealed battery in its place. The motorcycle works fine but if the kids ride it for more than a minute it will shut off, or if they try to go over carpet or up an incline it will shut off. after a bit it switched back on and works again.
There is a fuse off the positive batt lead that is fine but There is a small circuit board under the plastic "gas tank" that i believe must have some type of overload circuit..?
Is there a way I can bypass this function?
Thanks, Nick
Custom Wheels question
newbie
Hello everyone and thank you for the add. I have r[…]
Cruisin McQueen (nz)
