By iazybandit
#140220
I acquired two Super 6 Power Wheels (Big Jake) and Lil Dune Racer. Both use the A type connection (red batteries). I plan on putting a 12v SLA battery and using the original connectors in the event that I need to use the 6v battery or when I sell it.
I am making my own wiring harness for the 12v battery with quick disconnects and was thinking of buying some used 6v battery connectors so that it is it can be plug and play. Any issues using the 6v connectors on a 12v battery?
It pretty much looks like this:
So the end on the right will have the 6v connector that will connect to the Power Wheel. When I need to charge the 12v, I just disconnect the cable in the middle and connect the 12v charger.
By iazybandit
#140356
Suburbancharlie77 wrote:What's the gauge on those ends? 12 volt will require a 30 amp fuse, and 12 awg minimum. I have very similar ends, and I think their 18 awg..... if that's the case, no, it won't work.
10 gauge.
Picked up some 30 amp fuses. When I have the time, going to solder one half of the harness to the 6v plug and test it out.
I am glad to read that you come up with outstandin[…]
4x4 12v circuit issue
wondering how do you like the sportrax. I'm saw so[…]
SOLD SOLD SOLD!!!! Powerwheels Jeep Aftershock was[…]
Would also be interested in the same project. Livi[…]
