By sandyx
#146379
So I'm in a fix here. The car is a Sportrax BMW Baja 4x4, yes it got 4 drive motors stock.
The original circuit had its own mind as it used to go full speed w/o controls. It was too dangerous for the kid so removed it. Instead of an exact replacement, i got a 2WD rated board which I wired to run all 4 motors.
It got One MOSFET inside with an option for a second, wired in parallel. Its number is 200N03A which is very rare. Can't even find its datasheet.
WhatsApp Image 2017-07-10 at 17.38.36.jpeg (64.87 KiB) Viewed 1847 times
So replaced it with Two IRFz44 MOSFETS & checked. It worked but the Soft Start feature went missing, no response to speed control from remote & slight heating. Reverted to original 200N03A & all is well again.
So here I'm looking for a 2nd piece 200N03A so i could reduce load on the one i already have. Do anyone here have experience with such Soft Start circuits on their PW or similar? Any help would be much appreciated. )
By CJB
#146381
Just going out on a limb here, and I'm sure your experience level in component sourcing is comparable to mine so I may be talking to a mirror on this one but sometimes the suffix just refers to a variation, be it packaging, RoHS status, etc. and there may be dfferent prefixes associated with different manufacturers of a comparable part as well.
I found this datasheet from UTT (?)
http://www.datasheetspdf.com/mobile/807 ... 00N03.html
which would seem to be what you've got, spec wise. Much higher current rating than the Z44 (which I take with a grain of salt)
Of course, I can't find it on any of the big 5 distributor sites so it may be of no help after all. lol
Date code decoder?
