By shine
#111661
Guys
i have a feber ferrari f40 single 6v gearbox - 2x6v 12 ah battery
After all the reading I have decided to only upgrade the single dc motor from 6v onwards .. i have added tires grips for traction already.. gonna wire serial battery connection for 12v power
I'm thinking for a powerful single motor 12v+ for speed.. i need advice whicjh motor required?
any ideas? have added photo of what i have already
im from the UK
motor
By iDz Bowl
#111712
If you're looking for speed, why not just put two motors on the 12v battery? It seems that that vehicle already has a spot for a second motor.
Do you know which gears are on it?
By shine
#111905
thanks for replying..
I do know were to purchase a 2nd feber gearbox that would be 6v. but dont want this for traction as i have tyre traction rubber screwed in already
my question is what motor with cog do i need to purchase to upgrade the current 6v dc motor, i rather replace the motor with cog, but motors dont come with cog or pinion?
For test purposes i set a serial connection on the battery which gave 2x6volt - 12v power it flew like a rocket but then dint work then it did, i found out there is a full swith with a fuse i think, so gonna get 40amp fuse is that right?
Cheers
By shine
#111950
After the battery modifications of 2x6v battery's...
The car goes lke a rocket on our tough long carpet, but only for a few seconds.. then works again..then stops and starts?
There is a kill switch.. but no fuse box.
would i be right in thinking in cannot handle 12v serial connection on 6v dc motor.
if so can you recommend a better motor with a cog for the gearbox?
or will the feber 12v gearbox for the feber California work on the f430?
Cruisin McQueen (nz)
NICE ... that is sweet.
