By Oscarinho
#150378
Hi,
I want to upgrade the motorbike from 6V so i bought a 12V battery
and a 12V engine
but the problem is when I isntalled them It runs some meters and then turn it off.
We have a fuse between the battery and the circuit:
WhatsApp Image 2018-12-17 at 12.44.36.jpeg (118.41 KiB) Viewed 696 times
http://www.ottercontrols.co.uk/pb-series.html
But I've tried wihout the fuse and I burned one engine.
I tried with one standard 10A car fuse and break it as soon as I powered on the motorbike.
This is the relay we have:
WhatsApp Image 2018-12-18 at 15.14.55.jpeg (127.93 KiB) Viewed 696 times
So what is the fuse I have to put it between them?
Thank you in advance.
Oscar
#150395
If that relay is rated at 6v then it will burn up running at 12v. You would need to match a relay for the voltage you are running at.
6v rides are usually protected at around 20amps when stock . I would not go any higher than a 30amp fuse with stock wiring. After installing your new fuse, monitor the wiring temperatures to ensure they aren't getting too hot. Whenever you alter a ride on there are hazards involved. Do not over build the vehicle and risk harming your child. Safety first.
Electric Scooters
