By MatthewJ
#148741
So I have 2 power wheels, the F150 and a Dune Racer. The F150 has 2 batteries (24v mod) and the Dune has a 12v non power wheels battery.
Is there any way to hook up an external charge port so I don't need to remove the batteries to do so?
Ideally I want to charge both the f150 batteries the same time.
Thoughts?
-Matthew
By dlgg7
#148742
I've seen the 12v, 4-wire trailer connectors used for a connector on the truck, and then using 2 of the battery-tender harness I've bought on fleabay 4 for abt. $15. free shipping. I use for all my batteries the batter-minders that desulfate as well as charge and maintain 12v-2A from northern tool about $25. ea. Wire a quick connector for each charger into the male end of the trailer harness, and plug each charger in to charge 2 12v batteries at once. Just use one of the battery tender harnesses on your Dune and plug a charger into that to charge. I bought like 16 of the harnesses to make all my batteries universal to charge. Hope this gives you some help.[url]https://www.ebay.com/itm/4-x-Quick-Conn ... 1438.l2649
By Bigmac41288b
#148744
I have two of these mounted under the hood of an 18v mustang to charge the onboard batteries i have mounted under the seat. The battery tenders with the two pin connection plug right into them without any adapters. I love it because it’s so simple my 4 year old can plug it in himself when he is done playing.
Problems with remote shut down
I was looking for a way to be able to remotely sh[…]
Low voltage warning
So I've got this little tikes hummer that I've bee[…]
Building a new pool
Hello, I am new to this forum and have a quick que[…]
Lightning McQueen lowered
