#115844
I purchased 2 Kawasaki KFx ninja quads (green) I want to convert both to 18 volt... They have low speed for pedal and twist throttle.for high speed. Ib order not to cut factory wire but will if I have to.... is there a tutorial for this? Also what batteries and charger is needed?
#115878
He means, all the information you need is located in the FAQs. Please start there.
Specifically,
HERE,
HERE,
HERE,
And especially HERE.
We're always here to help with any questions you may have after you've done the research.
Welcome to the forum!
#116231
it true u cant i tried to day to do that but instead just straight wired all of it an used the twist throttle to go. it had no board inside by the way
Circuit breaker popping
