By Look_out02
#146623
I have been trying to get my kids gator back running this year, but I haven't had any luck. I checked the battery with my multimeter and it checks good. I have tried everything I can think of to troubleshoot but I cant find the problem. I connected the battery directly to the motors and they both worked. I tested each switch and they seem to be working. I even connected the battery and pressed the pedal, put it in gear and I got 12v between the leads for the motor, but as soon as I connect them to the motor, I show 0 volts. and that's where I'm confused. any thoughts on what to check would be greatly appreciated.
By dlgg7
#146660
For a start, have you unplugged the wiring harness from your switches and checked your switches with a meter? Could be a bad switch that shorting out either f/r or slow/fast. Be hard to see if there's a prob in the harness, possibly broken wire, check continuity between ends of harness. Sounds like you'll have to start at one end and ck eack connection and ck whats it connected to, not that many things to ck really. I've had 2 bad switches so far. good luck!
Huffy Lightning Mcqueen
