Anyone switch to full relays? Electrical gremlins 16v (4s) f150/traxxas 775
Posted: Wed Sep 20, 2017 5:30 pm
by mtxjohn
Hello all! New to this...upgraded to lithium 4s (16v roughly) (yes I know this isnt recommended for typical installs) and the traxxas titan 775 provide massive torque. Problem is ..sometimes the vehicle "quits" working. It did this on stock batteries too. Checked and the foot switch is providing 15v to the shifter...motors are brand new. Do these have a thermal fuse somewhere? I cant find one. Thinking of switching to ALL relays (I already found a 12v throttle switch alternative relay diagram). Just wondering do ALL the switches just get full power to them? I mean..this setup is doomed to fail. Wherever the contact is made to apply power...yikes! I have a pile of 30/40a car relays sitting around...
Re: Anyone switch to full relays? Electrical gremlins 16v (4s) f150/traxxas 775
Posted: Wed Sep 20, 2017 9:13 pm
by mtxjohn
Ok...found the answer. 5 relays needed in total. 2 relays for a "polarity reverse" "switch". (one physical dash mount switch for reverse, default will be forward) 2 relays for series/parallel switch which is the high/low. (default condition (87a) is low, switch will be for high). Planning on retaining foot pedal for on/off but adding 5th relay to take on that heavy load. Still unsure where the resistor goes in this plan for the brake attenuation.
Posted: Wed Sep 20, 2017 9:18 pm
by mtxjohn
Posted: Mon Oct 09, 2017 8:15 pm
by mtxjohn
Relays conversion completed. Now I just need to install it. I found amazon had a deal on five "hi powered" 60/80A relays for $20. I wasnt sure the 30/40 would do it...
Posted: Tue Oct 10, 2017 12:16 pm
by toycrusher
Keep the updates rollilng!
