By d00mzDav3
#147794
I am trying to follow the wiring diagram and am wondering how people split the connections so certain wires go to different connections?
By dlgg7
#147813
To make my connections trouble-free, slide heat-shrink onto wire first, then I strip back insulation (without cutting the wire) about 1/2" and open-up the strands by twisting in opposite direction their twisted, then I take the next wire that I'm joining and with about 1/2" stripped back and weave into, twisting new wire around the spliced wire. Solder these, then slide heat-shrink over and seal heat-shrink. If coming from a spade connector from a plug, I remove the connector from the plug in the back, and remove the old connector, solder the 2 wires together, and crimp into a new connector and put back into the plug. (I ordered the spade terminals off flea-bay that lock into the plugs like the originals.
Hi all, I Found this site looking for information […]
Simple soft start esc?
lol i guess not. after finally finding sort of an […]
KidTrax beetle trouble
Check for defective/open thermal fuse.
Wild thing seat switch bypass
we have a fried circuit board and they dont sell t[…]
