By SoGaGiles
#147848
Newbie here, been reading through these forums for a week but can't find what I'd like to do so maybe not possible. I have one of the "high quality" best choice products, 12v SKY 20**? Its the FJ style truck. I'd like to increase voltage to only the motors a s bypass the accessories ie: radio, lights and circuit board that everyone seams to fry on this model. I'm planning to cut vents in the compartment and put fans to each motor. I feel like I should be able to use voltage regulator, diods and fuses to protect everything except motors with the increase. I'm open to any comments or suggestions. Thanks
#147853
What kinda car is this? (12v or 24v vehicle?) Seem like a step down converter would be used for accessories. If 12v car, better change to 775 motor. These are all my guess since I don't know what kinda car you got.
#147854
The car is 12v with high/low speed and controller. I remembered i didn't put that in initial post so i updated it earlier. I'll check on 775 motors but I guess I should figure out exactly what shaft length and pinion size I have? Or is that universal for most current cars? My wiring dilemma is bypassing the small box that battery feeds to then feeds out to motors, shifter, pedal, accs.
Hi just introducing myself
