#148818
Hi All,
i know a lot of you have bypassed the standard pcb's when increasing the voltage to the car, although has anyone used a DC to DC step down? ie input 18v and output 12v to reduce the heat that frys the standard pcb
also, does anyone use an external acceleration & speed controller? if so can you post up links of where you sourced them from? The ones that i have found are big and bulky, looking for something that can control acceleration and speed in a small unit
thanks
Sam
If you're running 24v in series put in a set of St[…]
