#147222
Here are some good links:
Factory axle is 7/16" and most of these pneumatic wheels have a 5/8" bore. As suggested below you can get a piece of 1/2 PEX pipe which has a 5/8" OD and is very close to 7/16". I'm currently waiting on some 7/16" to 5/8" flange bushing/bearings to tighten up the tolerances.
http://www.saltydog.com/powerwheels/
http://forum.modifiedpowerwheels.com/viewtopic.php?t=10260
Hi everyone
Hi guys here Federico and my son Edoardo from ital[…]
I am afraid the gaps you have around your speakers[…]
Have you looked under the seat for a label with th[…]
New to the forum from good old Blighty
Just a quick hello from me in the UK Found the fo[…]
